displacement map problem - it just doesn't work
  • displacement map problem - it just doesn't work
    I've been trying to apply displacement maps to a stone texture I have but it does not show up. When I turn on the displacement in the materials menu and hit preview, only a black screen is showing.
    What might be the problem?
    The material and displacement map are .jpg files, correctly sized to each other, etc. The multiplier is 1 (although I tried a range) and other settings within materials are defaults.
    Any comments/suggestions would be most appreciated.
    Thanks!
    Re: displacement map problem - it just doesn't work
    The black preview is normal for a displacement material.
    Did you grouped/make component the displaced geometry?
    www.Top3Dstudio.com
    SU 8
    VfS 1.48.89
    Win 7 64-bit
      I never rely on the material preview. I just apply the material to a small patch in SU and test render it.
        40th,
        I tried it in all different ways - ungrouped and also grouped, applied to the whole group and within the group, etc...
          If you're using 1.05.30 I can take a look at your model.
          www.Top3Dstudio.com
          SU 8
          VfS 1.48.89
          Win 7 64-bit
