Re: error " we have encountered error(s) "
The error message is telling you to check the error log. We can't really tell you what's wrong without seeing the contents of the error log. Here's some info about the error log: http://forum.asgvis.com/index.php?topic=7503.0
=========System Information=========
platform = win32
country = UnitedStates
language = English
About to make our qapp
after make qapp
Made it after UIManager.initialize
C:\ProgramData\ASGVIS\Python26\Lib\site-packages\Ft\Xml\InputSource.py:346: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument
FtWarning, 2)
FtWarning: Creation of InputSource without a URI
Entering renderArchive
About to start readArchive - C:\ProgramData/ASGVIS/VfS/current_skp.xml
23.612000 seconds is how long it took to read C:\ProgramData/ASGVIS/VfS/current_skp.xml
2.694000 seconds is how long it took us to correct the file paths for all external texture file references in the scene.
(to ensure this process goes as quickly as possible, please be sure all references to external texture files are correct prior to rendering)
Traceback (most recent call last):
File "C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vray plugin.py", line 215, in add_to_renderer
vray_param = param.to_vray_param(renderer)
File "C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vray plugin.py", line 92, in to_vray_param
return self.value.to_vray_param(self.name, renderer, final_gamma )
File "C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vray types.py", line 348, in to_vray_param
return PyVRay.VUtils.DefStringParam(name, self.to_vray(renderer))
TypeError: argument 2 of PyVRay.DefStringParam() has an invalid type
File "C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vray render.py", line 328, in render
self.addAssetsToRenderer( self )
File "C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vray render.py", line 102, in addAssetsToRenderer
ref.plugin.add_to_renderer( self )
File "C:\ProgramData\ASGVIS\Python26\..\VfS\ASGVIS\vray render.py", line 408, in renderArchive
self.render()
28.501000 seconds is how long it took to read C:\ProgramData/ASGVIS/VfS/current_skp.xml
2.702000 seconds is how long it took us to correct the file paths for all external texture file references in the scene.
self.render()
I have installed demo version of Vray on Sketchup 8 an everytime I try to start SU it crash and the error window appers which says: 0000000(000000000:59) An invalid argument was encoutered." When I unninstall Vray Sketchup is working fine. I have Windows XP SP2, I was also trying to install it on SP3 where it was a same problem. My friend is using this on Win 7 where the demo is working perfectly. Other one is using it without problems on Win XP SP2.
Where is my problem ? Do I have to have something else installed in Windows? Is there problem with some graphic cards etc.? Open GL...?
Thanks for any help. I would really wold like to give it a try, then buy it and use it proffesionaly, but I cant even run demo version.
