Differences between academic and regular Vray
  • Differences between academic and regular Vray
    Hi All, I am going back to school soon and I would like to buy Vray. What are the differences between academic and regular version? I know that the price is one, is there any limitations with academic besides that you can not use it for commercial use (make money off it)?
    Thanks
    Re: Differences between academic and regular Vray
    Found the answer
      for the sake of anyone else out there that has the same question, you can't use the academic version for commercial work, and the price is discounted for students as well. Those are the only two differences between the commercial and academic versions.
      Devin Kendig
      Developer
      Chaos Group
        Resolution output?
        -Intel Core i7-930-<br />-12GB DDR3 SDRAM-<br />-ATI Radeon HD5970-<br />-1TB Hard Drive-
          shouldn't be limited in the academic version.
          Devin Kendig
          Developer
          Chaos Group
            Resolution output?
            heheheheheh thsi was so funny.....you are a patient man Dkending....hehehe so funny!
              in the past we did limit the output resolution, but if the resolution is limited, it's really hard to make renders for some presentations or projects in school. We ended up taking the resolution limitation out in... 1.05.30? It's definitely not there in 1.48.66 or later, I know that much for sure.
              I actually like these kinds of questions, you know, the ones I can answer without having to write code I dread the ones like "why doesn't this scene work?", the answer usually results in me having to do a lot of work ::cries::
              Devin Kendig
              Developer
              Chaos Group
