Hello there! I'm new to the forums and this software. I have picked it up quite well as it is quite intuitive, but still have one or two problems. with all the things I am trying, the rende times are slowing down quite a lot (I have a 2.0ghz core2duo with 384mb integrated graphics), so I thought I would ask some seasoned users.
Firstly, I wish to make a transparent material blurry, so any light coming through or any images on the other side are visible, but not clear. preferable it becomes more blurry if it is further behind the material.
Secondly, I would like to make a semi-transparent material, that blocks a certain amount of light per cm travelled. So a ray of light decreases in intensity a certain amount per cm of this material travelled. therefore a think amount of this material would be almost opaque, and a thin bit would be almost transparent
3. how do I change the position of the sun?
finally, I know how to add bump and displacement maps, but is it possible to make it react differently related to how close it is to an intersection, line or corner? is it possible to make it smooth the edges slightly?
thanks in advance to anyone who helps with my problems
