Problem when using .vismat to spherical model
  • Problem when using .vismat to spherical model
    Hi, recently i'm downloading .vismat file from ASGVIS named Crome&Stripe, it should be produced looks like this
    I've tried repeatedly (including re download the .vismat file), but the results are always like this
    is there any way/setting that I did not know to be able to get proper results?
    Pelase Help.... :'(
    Thanks in advance
    I'm using Win7, Sketchup pro 8.0.4811, VRay 1.49.01
    Re: Problem when using .vismat to spherical model
    ... Poor me...
    Still no one help me :'(
      looks fine to me... um, at least the vray part. What you need to do is get the mapping correct in Sketchup. Looks like it might be kind of complicated to map that texture to a sphere, so you may look on sketchucation for tips on how to do that.
        there's a plugin called UV tools that will let you properly map a sphere.
        Devin Kendig
        Developer
        Chaos Group
          Thanks for the reply, Masters
          So, this isn't something in the VRay setting, Ummm.... okay
          Trying to UV Tools right?,
          I'm going to Sketchucation forum
