someone ever had this problem?
every item is shown in sketchup, but when rendering some items dissapear
Re: every item is shown in sketchup, but when rendering some items dissapear
Exactly what version of VfSU do you use?
What you describe sounds like a known bug in the old versions.Please mention what V-Ray and SketchUp version you are using when posting questions.
Depending on you VfSU,
Im using an older version (1 behind the current one) and it has a hard time dealing with GROUPS. i just make components of everything (or explode, make component)
Also using the older VfSU i have found if a material is created and then additional faces are added, if you apply the material in SU sometimes the link will not follow in vray... in turn manually override the face material
And: it can also occur when a material has been applied and created, then removed withing VRAY material editor.
Good luck
