light cache seems to freeze
  • light cache seems to freeze
    has anyone experienced this?
    i'm using skp 8 with vray 1.49.01 and windows 7 pro
    when i render using irradiance map as primary engine and light cache as secondary engine the rendering seems to get stuck on the light cache very early on. as soon as i change the secondary engine to something like DMC or something else it renders fine. is this a bug? I would like to continue using the light cache because the images look better but i can't for some reason. this only seems to be a problem with some of my scenes strangely enough but i haven't been able to figure out why.
    any one know why?
    thanks
    L
    Re: light cache seems to freeze
    What's your Light Cache settings like?
      I'm wondering if you have semi transparency materials?
        its strange because it works on most scenes. i don't change any of the settings when switching scenes. it just decides to freeze a few seconds after the light cache starts.
        these are my settings
        http://img705.imageshack.us/i/captureutn.jpg/
        not sure what you mean by semi transparency materials. i always use transparent materials but in no different way on this scene.
          We have one option called transparency on the diffuse layer, if you want to make a semi-transparency material, you could use a gray color on that option instead of the default black color. I ask, because some users have reported the same issue when they use gray colors on the transparency slot for the diffuse layer.
            The transparency value in the diffuse layer is not black. which would make sense since its a transparent material. i use the sketchup transparency toggle usually to change this value since they seem to update each other. I still don't understand why it would work in some scenes but not in others.
              Is your render working fine if you remove the semi-transparency for the materials?
                i removed the transparency material but the rendering still seems frozen
