BLUE POOL WATER?
  • BLUE POOL WATER?
    I downloaded the "Pool water" texture from the Chaos Group website and used it in 1 of my models but there is no transparency - its looks like water but its almost black. Can anyone supply me with the correct parameters for the material settings
    [img][/img]
    Re: BLUE POOL WATER?
    Hi here are the material setting
    Reflection layer
    -fresnel mapping 1.33 IOR
    Diffuse layer - A color (100% White) on transparency - this is to make this layer 100% transparency
    Refraction layer-
    1.33 IOR
    Fog Color - 205, 247, 255
    Fog Multiplier - 0.08
    Displacement - use the water texture on the downloaded file for displacement
    Global option - disable
    Edge Length - 12 - this is to speed upt the displacement render.
    Optional - I use the same water texture on the diffuse color in order to control the UV mapping.
    Best
      Here is the scene that I use for the pool caustic video tutorial
      http://www.mediafire.com/?l8xyr3nqhca419b
