Help with another material!
  • Help with another material!
    Hello everybody, and specially Fernando hehehe,
    once again, i'm needing a little bit of help with a material...
    i'm trying to create a vitro block material for a house i'm making, and i used the maps posted by another user in this topic:
    http://forum.asgvis.com/index.php?topic=4310.0
    I need to be able to see siluethes from the other side, as well as light, i actually made a sceene with a window behind the vitro block wall to try to create the material, but it's not going very well...
    could you please give me a hand with it?
    my process:
    i made an square and applied one of the maps
    then i added a reflection layer
    went to difusse rollout and in transparency selected "A color" and played with the colors to try to get the right one
    and applied the bump and displacement maps with a multiplier value of .125
    so, what am i doing wrong?
    thank you again! ;D
    los campeones no nacen, se hacen...
    Re: Help with another material!
    Hey Omar! Did you try with only bump? I have trouble sometimes if I try to have both maps for a single texture. Also, it looks like his material would only be using bump since the geometry is not isolated to produce displacement.
    Andy
      hey andy...
      i'm tryin rght now... i also made a two sided material, but i'm still not happy with the result...
        Hi Omar
        Here is the material that I made. I hope it work for you. I have a greenish color for the Fog color, If you need a different color just change the fog color. I also use a displacement, but you could use bump if the material is to far from the camera in order to save some rendering time.
        Best
        http://www.mediafire.com/?2eek4mr9502514r
          wow... wow... ... mis respetos para ti fernando
          absolutely great, wow...
          what did you do? i was tryin to figure it out by myself cause that way i don't forget...
          could you write a little description of what you did? i mean, where was i wrong?
          really, thank you again...
            Hi Omar
            I attached the link to download the material. I think is better that you look at the material.
            Best, my friend
              oh i had not seen it.
              thank you again!
              have a nice day!
