Output resolution
  • Output resolution
    Friends,,,
    Is there any option to set the resolution of the output before rendering the scene?
    I think the default resolution is set to 96 dpi (both in horizontal and vertical),, Can we change it to 150 or 300 for example?!
    Thanks
    Not sure that there is such an option. Why would you need to set the resolution in vray? Specifically, what program are you using that the resolution is important? Most programs (like photoshop) you can set the resolution to whatever you need. I always just think in terms of absolute pixels, and resolution will vary depending on my end use.
