hi ...when I try to use the water shader in the vray material for bump or displacement and send to render....often sketchup and vray simply crash.....i use the last version 1.49.01
water shader material bug
Hi
Originally posted by a3rosmith View Posthi ...when I try to use the water shader in the vray material for bump or displacement and send to render....often sketchup and vray simply crash.....i use the last version 1.49.01
I have tried to get around this situation with the bump as recommended in the previous forum Asgvis
today I saw this tutorial about water which seemed to me quite interesting
http://www.facebook.com/media/set/?s...5347596&type=1
good luck!Intel(R) Core(TM) i7 975 Extreme Edit. 3.33GHz / 6.4GT/s 8Mb box / Motherboard Gigabyte GA-EX58-UDS / Asus GForce GTX275HDMI 896DD3 (12Gb) / Windows 7- 64bit / Sketchup 2013 / V-Ray
