Vray for maya displacement UV set
  • Vray for maya displacement UV set
    I want to use 2 differents uv set for setting up my 2d displacement. I ve seen people doing it in 3dsmax with the material id and it seem to work perfectly but when I try it in maya with the Uv chooser... Its always the first UV that is use.
    Can you post a scene for this? Also, which displacement type are you using (2d, 3d or vector)?
