Reinhard into NUke
  • Reinhard into NUke
    i am trying to implement the same Reinhard color mapping into Nuke.
    I have been eyeballing the settings till now, but i am now trying to move to a more controlled workflow where i can preview using the vray color mapping, but render final in linear and micro tune in nuke, but on the basis of the same curve.
    So, i am asking if it possible to know the implementation algorithm of the reinhard curve in vray, including the controller slider to match the settings in nuke.
    I wasn´t able to find some clear explanation on google.
    Thanks in advance.
    T
    From the online docs:
    Reinhard - this mode is a blend between exponential-style color mapping and linear mapping. If the Burn value is 1.0, the result is linear color mapping and if the Burn value is 0.0, the result is exponential-style mapping.
      Thanks Thorsten, i have read the documentation but it was unclear to me the way i should blend the two extremes.
      If i blend them straight forward like the mix knob in the nuke nodes should it be ok? is it the same as flatenning the exponential curve?
      i am not too experimented on the math side.
      Thanks again.
      T
        I'd say linearly blend the results. I'd say gizmo up an exponential and a linear one, and linearly blend them. Vlado would prolly know better. I am not using Reinhard for anything so i would not know first hand.
        Regards,
        Thorsten
          Thanks man. Will try tomorrow.
            A while back somebody posted these images on this forum as an example for what the Rheinhard curves does.
            I believe you can reproduce these curves in nuke with the colorlookup.
              Hi there,
              my name is Giacomo, I might sound new but I was previously registered with a different userID and company.
              I'm interested as well in recreating the reinhard color mapping in nuke. Until now I've tried to match it with a colorLUT but I have the feeling it is not 100% right.
              Does anyone have a better workflow?
              Vlado can you please give us some more infos?
              Kind Regards,
              Giacomo.
