Launching VRay RT from an Scripted Button (Python)
  • Launching VRay RT from an Scripted Button (Python)
    [Maya 2012 64Bits, V-Ray for Maya 2.0 Beta 2, Windows7 64Bits]
    How can I launch VRay RT from a button? Its always return an error:
    Code:
    # Error: TypeError: file C:\Program Files\Autodesk\Maya2012\Python\lib\site-packages\maya\app\commands.py line 17: Object  is invalid #
    Here is the code with several tries:
    Code:
    import maya.cmds as cmds
    def launchRTRender(*args):
        print "launchRTRender"
        cmds.eval ("renderIntoNewWindow iprRender;") #Try 1
        #cmds.eval ("RedoPreviousIPR;") #Try 2
        #comrt = 'vrayStartIprRender "%s" %d %d "%s"' % ('renderView', 640, 480, "persp" ) #Try 3
        #cmds.eval (comrt) #Try 3
        #cmds.showWindow('MayaWindow') #Try 4
        #cmds.setParent('MayaWindow') #Try 4
        #cmds.eval ("IPRRenderIntoNewWindow;") #Try 4
    cmds.window()
    cmds.columnLayout()
    cmds.button(label='RT Render', c=launchRTRender)
    cmds.showWindow()
    Thanks!!!!
    IPRRenderIntoNewWindow is a mel function, so you need to use maya.mel.eval("IPRRenderIntoNewWindow;") instead of maya.cmds.eval("...").
    I've tried it an it works like a charm.
    /Teodor
    V-Ray developer
      Thanks!! Works perfectly!!
