V-Ray 2012 Destrebuted Rendering issue
  • V-Ray 2012 Destrebuted Rendering issue
    Hello,
    I have been using Distributed rendering for 2 months now, I have 10 render machines on the network, all works fine but Im working on this project where some of the machines don't render properly, it leaves dark or it doesn't render the correct colour!! in other words it doesn't render the texture materials.
    I tried to render locally the same project it renders fine, but when i use the destrebuted rendering it gets messy..
    I have re-installed V-ray and nothing changed!
    I have the firewall open, nothing is blocked..
    Kindly find the attached 2 image to understand the issue.
    Many thanks,
    Elias
    you should email chaos for full forum access as a chaos customer
      I fix my distrubuted rendering problem installing vray 2.0 SP1
        esadi - make sure the files are with main 3D file location first
