rendering depth-map
  • rendering depth-map
    Hi all!
    Does anybody knows how can I render different objects in the same scene with this result?
    http://www.google.es/search?q=depth-...w=1280&bih=857
    I want toshow the colors depending on the distance between the objects and the camera. thanks!
    Use the _ShowZBuffer command. (It's pure Rhino!)
    Bye.
      You could also use the Z-Depth channel inside the V-Ray. The Z-Depth is located on the V-Ray channel tab on the V-Ray option. The only thing that you have to define is the distance form the camera to the closer plane of the depth and the distance from the camera to the further away plane.
      You can watch this video to have an idea of the Z-Depth channel.
      http://www.youtube.com/user/ChaosGro...48/s9KCgGQtUfk
      Best
        Damien wrote a script that set the max/min distance of selected objects. Here the version ready for a Rhino button:
        -_RunScript (
        Option Explicit
        'Script written by Damien Alomar
        'Script copyrighted by ASGvis, LLC
        'Script version Wednesday, December 3, 2008
        Call SetZDepth()
        Sub SetZDepth()
        Dim Vray
        Set Vray = Rhino.GetPlugInObject ("V-Ray For Rhino")
        Dim depthObjs, currPlane, viewPlane, viewBB
        Dim midBackPlaneCP, midBackPlaneWorld, backPlaneDist
        Dim midFrontPlaneCP, midFrontPlaneWorld, frontPlaneDist
        Dim blkOwhite, prevMin
        depthObjs = Rhino.GetObjects ("Select Objects to be considered for Depth Map", 8+16+32, False, True)
        If IsNull(depthObjs) Then Exit Sub
        If Not IsNull(Vray) Then
        prevMin = Rhino.GetDocumentData ("Vray zDepth", "MinBool")
        If IsNull(prevMin) Then
        prevMin = True
        Else
        prevMin = CBool(prevMin)
        End If
        blkOwhite = Rhino.GetBoolean ("Set Minimum Value as White or Black?", Array("MinAs", "Black", "White"), Array(prevMin))
        If IsNull(blkOwhite) Then Exit Sub
        Call Rhino.SetDocumentData ("Vray zDepth", "MinBool", blkOwhite(0))
        End If
        Rhino.EnableRedraw False
        currPlane = Rhino.ViewCPlane
        viewPlane = Rhino.ViewCameraPlane
        Rhino.ViewCPlane ,viewPlane
        viewBB = Rhino.BoundingBox (depthObjs, Rhino.CurrentView ,False)
        midBackPlaneCP = AveragePoints (Array(viewBB(0),viewBB(1),viewBB(2), viewBB(3)))
        midBackPlaneWorld = Rhino.XformCPlaneToWorld (midBackPlaneCP, viewPlane)
        backPlaneDist = Rhino.Distance (midBackPlaneWorld, Rhino.ViewCamera)
        midFrontPlaneCP = AveragePoints (Array(viewBB(4),viewBB(5),viewBB(6), viewBB(7)))
        midFrontPlaneWorld = Rhino.XformCPlaneToWorld (midFrontPlaneCP, viewPlane)
        frontPlaneDist = Rhino.Distance (midFrontPlaneWorld, Rhino.ViewCamera)
        If IsNull(Vray) Then
        Rhino.Print "V-Ray Scripting is not available...Minimum Z-Depth = " & Round(frontPlaneDist, 6) & " Maximum Z-Depth = " & Round(backPlaneDist,6)
        Else
        Call Vray.AddVFBChannelByName ("Z-Depth")
        If blkOwhite(0) Then
        Call Vray.SetzDepthWhiteVal (Round(frontPlaneDist, 6))
        Call Vray.SetzDepthBlackVal (Round(backPlaneDist, 6))
        Else
        Call Vray.SetzDepthWhiteVal (Round(backPlaneDist, 6))
        Call Vray.SetzDepthBlackVal (Round(frontPlaneDist, 6))
        Call Vray.SetzDepthClamp (False)
        End If
        End If
        Rhino.ViewCPlane ,currPlane
        Rhino.EnableRedraw True
        End Sub
        Function AveragePoints (arrPoints)
        AveragePoints = Null
        If Not IsArray(arrPoints) Then Exit Function
        Dim avgPt(2), i, j
        For i=0 To Ubound(arrPoints)
        For j=0 To 2
        avgPt(j) = avgPt(j) + arrPoints(i)(j)
        Next
        Next
        For j=0 To 2
        avgPt(j) = avgPt(j)/(Ubound(arrPoints)+1)
        Next
        AveragePoints = avgPt
        End Function
