Error message on SKP 8 Mac OSX while rendering
  • Error message on SKP 8 Mac OSX while rendering
    1) Figured out how to install V-Ray for Skp on my Mac OSX
    - the plug-ins folder first said it could not be found, so I manually moved the vray plug-ins into HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins
    2) However, when I attempted to render my model (I later tried rendering a simple white cube to check), I receive the error message:
    "We have encountered error(s) while trying to render..."
    I typed ASGVIS into Finder then went to ASGVIS\VfS\vfs_stderr.txt to see what it said about my problem. This is what it said:
    File "/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/RubyToPython/ASGVIS/vrayrender.py", line 199, in initRenderer
    raise Exception("Invalid V-Ray Plugin load wildcard provided...no libraries loaded %s" % vray_plugins_load_wildcard )
    Exception: Invalid V-Ray Plugin load wildcard provided...no libraries loaded /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/RubyToPython/vrayplugins/libvray*.so
    Any hints on what to do? I need a rendering by Friday and I'd rather not use FormZ!
    Joe - e-mail back please!
    You shouldn't have to manually move anything. Are you sure you installed for SketchUp 8 and not SketchUp 7? By default the installer will try to install to SketchUp 7. It looks like the product is having trouble finding everything it needs. I suggest doing a reinstall, and ensure that you are installing for SketchUp 8.
    Devin Kendig
    Developer
    Chaos Group
