Multiframe incremental for animation in maya
  • Multiframe incremental for animation in maya
    Can we use multiframe incremental mode for animation in maya?
    because to use animation prepass we need to cache the light in single system...which take lot of time...
    Or if we cache on multiple systems...do we get flickers in animation...
    Thanks,
    Ajay
    Iam using IM for primary and LC for secondary. Each frame for caching is taking 40 mins. The animation is of 125 frames. If I go for animation prepass method, it will take almost 4 days just for prepass light caching. That is the reason I was wondering if I can go for multiframe incremental for a file with animation...will it be flicker free....
    thnx,
    Ajay
      You can cache the irradiance files across a farm. You can also cache it at half res to save you some time.
      KEITH ROGERS
      Learn the rules like a pro so you can break them as an artist.
      http://www.3layersofparallax.com/
        we have Royal render farm in office...But its not rendering the prepass in sequence order....will that matter...
          It is rendering prepass in the sequence of every 5 th frame - 1,6,11,16,21,16
            Funny you should say that as I was wondering the same thing about the order. It would make sense if it didn't work I guess. So not sure how clever Vray is under the hood at solving that problem. Out of interest have you turned off render final image in the globals. That will help your times a little on the prepass. GI is great looking but a pain to implement in animation without heavy rendertimes it seems. Sorry I couldn't be more help but I'm struggling with it myself.
            KEITH ROGERS
              while doing prepass, Iam offing render final image
