Vray Rendering Single Element
  • Vray Rendering Single Element
    Dear Forum,
    I cannot find a solution to rendering a single element without render the entire scene with all the passes.
    An example is:
    After I complete my render with 10 elements, I need to reRender just diffuse pass. How can I reRender just it?
    At this moment, everytime I need to recalculate just diffuse pass, vray FB recalculate all kind element of the scene (lighting, shadows, ecc...)
    Help me please!
    Thank you
    Simple answer, you can't.
      but Why? it is absurde ... It is the main concept of render pass.
      It is causes by VFB?
        It's because vray doesn't calculate each of the components of the render (diffuse, spec, reflection, shadow) and add them all together at the end. It takes all of the render elements from your main beauty render instead.
          Renderelements != Pass. You might want to write to support for forum access too.
            But there is the same problem also in Maya (I don't know if Vray manage passes and not only render elements ...)
            PS: you know why I cannot access to generalist 3ds max forum section and just for the public section? thanks
              As mentioned above you should email chaosgroup support so that they enable your account for the other sections.
              Regards,
              Thorsten
                I m sorry, I sent an email to chaos group support and hotmail detect it as spam....
                Thank you
                however you know if in maya there is the possibility to use render pass with vray?
                  Anyone know if vray support Maya render pass please?
                  Thanks
                  Thank you
                    there is a vray for maya section on this forum. try your question there if you have already sorted out your forum access with chaos group
