render image to different directory than the project directory?
  • render image to different directory than the project directory?
    Is there a way to specify full path for my final output image independently from the project path similar to 3delight? I'm looking around the render globals but can't seem to figure anything out.
    The way we set up our 3delight renders right now is to set the project to c:\temp and set path of our render images to our server \\render\projectname\etc\etc\. Only the finished images will be saved on our pipeline server. This way we don't end up with unwanted directories and cache files all over our pipeline server.
    You can certainly put a full path for the output images. There is nothing specific you need to do beyond simply entering the full path in the "File Name Prefix" field in the V-Ray Common tab of the Render Settings dialog.
