Vray Reflection
  • Vray Reflection
    hi ,, i have a problem with my Vray when i add the reflection layer to the material it does not appear on the material when i do the render i checked every thing i dont know what is the problem i did every thing and it still the same dont know why so help please ..
    Copypasta from: http://forum.cgpersia.com/f21/vray-r...#ixzz1p3hTYlMr
    Hi Rebin
    One of the key things about materials with reflection, is they need to have something to reflect.
    So for instance, if its glass, then there needs to be something to reflect in the glass - an image or another part of the model.
    If this isn't the problem, then I suggest you post an image so we can see whats going on.
    David
    SU8
    vray 1.49.01
      hi David thx for ur help bro
      ill explain what i mean
      for example i have a cube shape with black color
      and this is the Vray material editor settings
      and this is what i got when i do the render process ..
      depending on what u said david i adde two plains infron of that black cube and the problem is the same ..
        I think David is right. Try putting something like a 2D tree in front of the cube (not behind like you show).
          hi andy
          do u know what i want??
          i want to create a reflective plastic cube ...
          ill put a tree infrot of the cube n post it here ..
            Hi Rebin
            Mmm - your scene is very devoid of features, so its really difficult to show the effect of any reflections.
            Tips: - never use a totally black (0:0:0) material for your test - its like soot and doesn't bounce light.
            If you are experimenting, then use a sphere for your example - it should reflect like mad!
            Put an image or two around the scene, so it will be obvious when it is reflected. If you want a reflective cube then you wil need a sky (and clouds) so the reflections have something to work with.
            To start with, I would ensure that the colour in the 'reflection' box is not black. black indicates no reflection, white indicates maximum reflection. (Your example above looks black) - unless of course you have a 'fresnel' material, but that another story!
            something like this http://img232.imageshack.us/img232/6...ritest2ox7.jpg
            David
            SU8
            vray 1.49.01
              thank u very much guys 4 ur help i really appreciate that
              daivid look i placed a tree infront of the cub this is what i got
              and i want to reach this kind of plastic reflective cube
                Ditto what everyone else said. Also you could place an hdri map in the background slot of the environment rollout. That way your reflective cube will have something to reflect
                  Great i will insha allah thx guys for the help
                    hey rebin, you need to do a studio setup to do what u want to do, meaning there needs to also be a floor, rgt now your object is just floating in space my friend. put it on a floor. look for studio setups and then u will get the real drift
