This conversation initially started in
http://www.chaosgroup.com/forums/vbu...881#post545881
But since it turned out VDMs aren't support in VRay for Softimage yet, it morphed into a VRay for Maya question and I'm moving the it over here to a more appropriate
area of the forums.
I do have an example of a vector displacement that I've been having problems with in VRay, but I don't see any way to attach the file here in the forum.
It's relatively small, approx 4.25 MB, so it should be email-able if necessary.
Also, one thing that I've noticed that varies from the tutorials and forum threads that I've read, is that you really don't need the Maya displacement shader.
You can just plug the VDM straight into the shading group's displacement slot. It doesn't to seem hurt if you use the displacement shader but it doesn't
appear to have any benefits either.
Thanks,
Jeff
area of the forums.
If you experienced troubles such as random artefacts on your geometry when displaced or not displaced at all it would be nice to send us a scene to investigate.
Thanks,
Jeff
