use camera path farme range
  • use camera path farme range
    in my moving animation
    when i use "use camera path" in my 750 frame animation the "GI Rays" scattered along the path of my animation and that required High number " GI Rays" to give acceptable GI result, and increase total rendering time
    I am confident that the "GI Rays" i calculated in frame 0 will not used in frames 500-750 [in my animation at least] so is there anyway to limit the camera path calculation a frame range ????
    i tried manually change animation time range but i Confused with overlapping frame
    in my moving objects animation
    when i use "use camera path" in my 750 frame animation the "GI Rays" scattered along the path of my animation and that required High number " GI Rays" to give acceptable GI result, and increase the total rendering time
    I am confident that the "GI Rays" i calculated in frame 0 will not used in frames 500-750 [in my animation at least] so is there anyway to limit the camera path calculation to a frame range before and after my current rendering frame????
    i tried manually change animation time range but i Confused with overlapping frames
    and sorry for my bad english
