Hi, I'm having trouble installing v-ray on my mac. It says to specify the installation folder, however when I do so it says that the 'plugin's folder doesn't exist' no matter what I have tried. Please help
Are you trying to install V-Ray 1.49.01 with SketchUp8? Can you please try manually adjusting the installation path to reflect the version that you have installed? This is usually as simple as changing the 7 to an 8 in the window that gave you the error. If you continue to have trouble please email vraysketchup@chaosgroup.com.
