Hi Guys,
I'm hoping I can get this problem solved tonight if possible. Vray is currently saving all the information in the right column (maps, diffuse, etc.) for each material. For instance, were I to select paver 1, and then select paver 2, paver 1's map, diffuse, reflection info will still be in the right column. This gets unbelievably confusing when working with 20+ materials. Has anybody had this problem?
Thanks!
Ryan
Thanks!
Ryan
