Hello all !
I have noticed differences between vray RT GPU and CPU when rendering bump maps : it seems bumps are somewhat stronger with CPU.
What is the reason for this ? I am using vray RT 2.0 SP3 and have set bitmap size to maximum.
I wish both would be the same, because GPU is a lot faster, but has some limitations, so quite often I have to switch to CPU, and I would like my render not to change when I do
Thanks in advance,
Yannick
Thanks in advance,
Yannick
