multiple pcs
  • multiple pcs
    Hi all,
    I heard that on one of the latest demos, that vray RT can work across multiple CPUs (in CPU mode).
    This may be a dumb question, but does this mean that with 2 pcs hooked up, the RT CPU will be using all cores at once?
    Also, will this use off all availble cores apply to the Bidirectional Path Tracing.
    Cheers,
    Steve
    V-Ray RT can use distributed rendering to render on several machines at the same time.
    In the latest versions, the bidirectional path tracer supports distributed rendering as well.
      Great stuff. Cheers for the info.
      Steve
