In 1.50.216 when I import a model into an existing environment a dialog box now appears warning of a duplicate material. Indeed there is already materials with the same name in the environment as well as imported model. However this dialog box never used to appear before 1.50.216. I'm importing files via batch and even using the _-Import command doesn't suppress the duplicate material dialog.
Two things I'm wondering:
Is there anyway to make the setting of duplicate materials sticky in an option so that it behaves the same way without prompting?
When -Import is used there shouldn't be a dialog box appearing. Can this be suppressed and/or the option be shown on the command line instead?
I had to revert back to 1.50.202 and things are better again.
I hope this is fixed soon as it really interferes with my ability to do touchless batch rendering.
