Large Arc Reflection problem
  • Large Arc Reflection problem
    I have tried changing every setting I can see/think of and I continue to have this large arc reflection through the middle of my rendering. I am using sketchup 8 pro, vray 01.49.01, and windows 7 with new dell that has a 3ghz Xeon and 12 gb of ram. There is an image here:
    http://imageshack.us/photo/my-images...e20120726.jpg/
    Any help would be very appreciated.
    Thanks,
    Rob
    Do you have a refraction layer? Looks like it might be a cut-off of your fog. Try removing the refraction layer if that's the case.
      Thank you very much for your reply!
      I am a new user, so I definitely did not set up an fog/refraction layers. But I am not sure I completely understand your answer. Are you saying that I have fog turned on in the refraction layer my "glass" material and that the cut-off set improperly? If so, I don't need the fog at all. I'll try to remove it. Please reply if you see this and my description of your initial reply is not what you mean.
      Thanks again. This has been plaguing me for months!
