Displacement mapping ???
  • Displacement mapping ???
    Hi everybody,
    First, I apologize if this question has been asked on the forum, I did my research but I can not find what I want, and in addition I speak badly English.
    My Problem : I want to know how can i adjust my texture when i have no texture. The only one texture i have is the displacement. My diffuse textuse is a color. Here my texture is a roof zinc :
    you can download the texture here
    here is the image that was with the vismat texture file :
    And this is my test render : i work in meters but its same when i turn my unit on Feet. How can i adjust my texture ? Please.
    Here is my render :
    Thank You.
    https://www.behance.net/Mala_Suerte
    My Render
      Go ahead and also apply your displace texture as a diffuse map. Then click on the transparency mapping button, and pick TexAColor. Select White as the color.
      This will make the diffuse layer 100% transparent to vray at render time, but your map will be visible in sketchup, allowing you to scale/position.
      Dave
