Depth of Field - everything is blurry!
  • Depth of Field - everything is blurry!
    hi there,
    maybe you can help me. i tried to render an image with the DoF-Tool from vray.
    i tried a lot of numbers and used the tutorial of nomeradona... but i wont work, everything is BLURRY...
    i think it doesn't understand the "override focal dist"-order i give to vray...
    i work with milimeters (europe-standard) - my 'sharp' element is 1300mm in distance to the camera, this are around 52 inches.
    look at the attachements, maybe u can see something i did wrong?
    THANKS FOR ANY HELP ANS USEFUL TIPS!
    do you want to share to me your scene.. i will see it.
    http://www.nomeradona.blogspot.com/
    http://www.sketchupvrayresources.blogspot.com/
    http://www.nomeradonaart.blogspot.com/
      here it is... thanks for haveing a look at it!
      http://www.those.ch/transfer/glastest.zip
        I looked at your scene and the problem is that your F-Number is too low. You have to increase the F-Number. I tried with 14 and the DOF came good. You have to be aware that the F-Number also control the exposure. So if you increase the F-Number you will get a darker image. You will have to decrease the Shutter Speed or increase the Film ISO to compensate the exposure.
        Best
          Exist a good tutorial of Dbrenders, but now unfortunatly I can not find the link! :S
          I found this, may be it will be useful!
          http://www.exposureguide.com/exposure.htm
          Intel(R) Core(TM) i7 975 Extreme Edit. 3.33GHz / 6.4GT/s 8Mb box / Motherboard Gigabyte GA-EX58-UDS / Asus GForce GTX275HDMI 896DD3 (12Gb) / Windows 7- 64bit / Sketchup 2013 / V-Ray
            Hi
            This is anotther very good tutorial that explaind how to deal with EV.
            http://www.cg-blog.com/index.php/201...d-dof-vray.htm
              hi Fpedrogo!
              thanks a lot for this excellent tutorial of Ciro Sannino!
              especially the importance of the "apertures" because although with different values ​​if get the same amount of light exposure, in accord with some experts say, the resulting image is not the same, at least, in real photography!
                Here's another articles on F-stops in vray - http://joconnell.com/2010/12/depth-of-field-in-vray/
                  Here is Dbrenders tutorial
                  http://sketchupvrayresources.blogspo...dbrenders.html
                    thanks to all of you guys, i will try this next week!! thank you so much
                      hi there, i tried again - and failed. my render output is everytime blurry. i have no sharp element in my rendered image. as u told me i tried with F-Number 14 and ISO200 - nothing happened. the result is still blurry, not that heavy like in the first post, but blurry... is it, because i am working in milimeters? i can chance every number several times, but the rendered image is blurry in any way!
                      i changed the FoVoverride from 1 to 20, 38 and up to 100 - everytime the same image... WHAT!!! =D
                        check your "Override Focal Dist" - this is the distance from the camera to your focus point (in inches - multiply by 25.4 for mm) Need to have that box checked to use a specified distance.
                          i have always checked the box "Override Focal Dist" - the camera is around 1020mm distance to the glasses. so, as u says, it has to be around 40 inches.
                          other prefs: aperture 1.0 / center bias 0.0 / shutter 12.0 / ISO 100 / F-Number 14
                          still blurry picture.... i don't get it =/
                            Did you just say this "is it, because i am working in milimeters?"
                            Why are you using inches there, but working in mm?
                              sketchup model units are inches, so the units in the vray dialogue boxes are in inch.
