vray and spotlights
  • vray and spotlights
    Are there any known issues with using maya spotlights with vray? OR is there anyway to make rectangle lights behave more like spotlights?
    I assume that means you are having issues with spot lights - can you explain a bit more?
      Nah actually spotlights seem to be working just fine. Haven't run into any problems. Just wondering if there are any bugs I should be aware of before I start using spotlights everywhere.
        Well, there are no open issues related to spot lights in our bug tracker, but of course that doesn't mean anything...
          I have one for you Vlado,
          when using linear workflow, the edge of the spot light is sharp, disregarding the penumbra. If I use for example the Ies vray light, the problem doesn't happen.
          Yannick
            Add V-Ray attributes to the light and set the cutoff to 0.0
