cells diasapear.
  • cells diasapear.
    Hej. I wonder why cells are disappearing, when I drop a column of water to the floor it climbes up on the wall and as it breaks-fall back on the wall, lots of cells disappearing. Like those evaporated or something. But a 10cm water or similar thing wont just evaporates. Also this way the volume of the liquid will be significant less. Is there a way to turn this behavior off?
    I was thinking that phoenix could be used as a pre CFD for special cases where from the flow we could estimate sooner what happens, and then on next stages use only CFD solvers. It takes ages for CFD to come up with the Physically correct results with force etc. At first stage the speed and the volume of the water would be a good estimator for me.
    I was wondering the maybe ChaosGroup have plans to develop a CFD solver?
    Is there a newer demo version maybe, or a road-map what you plan to do with it?
    THX!
    btw, the cell reduction in the preview by logic should be the other way around. 100 is one hundred percent reduction.
