Rendering Problem
  • Rendering Problem
    Hello Guys, im having a problem with PhoenixFD, i have installed the plugin a works fine it simulates and everything, but when i hit the render button in vray nothing happens, only renders de source sphere. Any Suggestion?
    Thanks
    Kai
    i suppose you are trying to simulate liquid, and did not enable geometry+solid options in the render panel, are you?
    ______________________________________________
    VRScans developer
      Hi Ivaylo, thanks for the reply. thats not my problem, in fact i am doing the most basic simulation, a Grid, a Source, a sphere inside the grid, the connection from the source to the sphere, i see the sim in viewport, but when i hit render, i only see the sphere, maybe im missing something... i have not a clue...
      Kai
        Max or Maya? Which version of V-Ray? Is it working with the standard examples?
        V-Ray/PhoenixFD for Maya developer
          Maya2012 x64, Vray2.2, PhoenixFD demo version. where i can found the standard examples?
          Sorry about the newbie questions, i want to try phoenix to tell my bosses to buy the plugin, but i must show something for this to happend.
          Thanks
          Kai
            Here is the help for the examples and what they should do:
            http://www.spot3d.com/phoenix_maya_20/samples.htm
              where can i download the samples?
              ty
              kai
                soory about this, i found the samples...
                ty ivaylo!
                ill check it and post the results here
                ty
                kai
