Distorted rendering in Parallel view
  • Distorted rendering in Parallel view
    Hello,
    I am trying to overlay line-work onto rendering and that usually works flawlessly in perspective or flat (top/side) view - I render and use the Make2D command from the same view, then merge the rendering and lines in Illustrator. However, when I do that in parallel view (axonometric) the rendering does not match the lines. I tried to render in Rhino render to see if the problem is with the rendering or with the lines and Rhino Render works. Is there a setting in VRay that I need to address in order to keep my camera from creating distortions?
    Thank you,
    Diana
    You need to disable the physical camera, only the default cam works for parallel views. Help this?
      Thank you! That worked perfectly!
