Need to create Ink in Water effect
  • Need to create Ink in Water effect
    Is it possible to achieve the same effect with Phoenix as this Fume setup.
    http://www.youtube.com/watch?v=PjTxaAKmbtE
    Would you use liquid or just standard fluid setup?
    Mainly I want to know how to get the turbulence looking like that as the ink dissipates.
    Will also use Krakatoa to render.
    Gavin Jeoffreys
    Freelance 3D Generalist
    yes, see the sample scene finesmoke. you may use krakatoa for better rendering, it supports phoenix, or render it as fog like in the sample.
    ______________________________________________
    VRScans developer
      Thanks Ivaylo for the quick reply.
      It's not the render I am worried about. It is more the best way to achieve the fluid dynamic.
      Is it a moving source in a liquid, or is smoke in air with low gravity.
      Just wondering the best way to get all that fine slow turbulence.
      Thanks
      Gavin Jeoffreys
        smoke in air, no need to simulate liquid, if no liquid surface is needed.
        VRScans developer
          is there a clear tutorial anywhere about connecting phoenix with krakatoa?
            i think there is no such a tutorial. but paul oblomov can help you, he made this video
            VRScans developer
              There's nothing complex - just export particles inside phx. Then add krakatoa and point it to these particles. That's it.
              I just can't seem to trust myself
              So what chance does that leave, for anyone else?
              CG Artist
                I modded the Finesmoke example here:http://www.chaosgroup.com/forums/vbu...tercolor-Smoke
                There is an invisible obstacle and a moving source.
