Help?
  • Help?
    Hi All,
    I'm fairly new to vray for sketchup...I wanted to kindly see if there would be anyone out there that would take a little bit of time
    to help me render something I have in sketchup to look similar to these on this website. http://http://www.eqaofficefurniture...configurations
    I would greatly appreciate any help or tips I could get, such as lightning styles to use, and any settings to use before rendering.
    Thank you.
    The link seem to be broken for me. Can you upload the reference image or a working link.
    Best
      http://www.eqaofficefurniture.com/im...ypical_H20.jpg
      Thank you!
        Heres a couple more... http://www.eqaofficefurniture.com/im...ypical_H07.jpg
        http://www.eqaofficefurniture.com/im...l-003-main.jpg
        I would like to produce images like these...furniture on white floor, white(blank) surrounding.
          Hi
          You could create those render using just GI. So you have to go to the Environment and remove the TexSky from the GI(Skylight) and Background. You can also use a Blurry studio HDRI to get soft shadow and nice reflection in the reflective object. Tho get the dark and strong shadows you can use AO with a big radius.
          If you want to get the pure white floor and avod the reflection of the HDRI (if you are using one) you should override the Background of the floor material using and AColor white.
          Best
            i use these methods, works nicely if you find the correct hdri
