Hello, in Mental Ray or Maya Software Render I can choose Premultiply or not. How can I render in in VRay Unpremultiplied?
Rendering unpremultiplied Alpha
Originally posted by PandaPanda View PostHello, in Mental Ray or Maya Software Render I can choose Premultiply or not. How can I render in in VRay Unpremultiplied?
I got a similar question.
I want to render it my scene on a black background for compositing
At the moment I have Vray Sky in the GI Environment slot and a gradient in the Environment Map (Environment and Effects Panel)
Is there a way I can have the scene rendered against a black background and also have the Environment clean in a different channel?
Originally posted by nomads View PostIs there a way I can have the scene rendered against a black background and also have the Environment clean in a different channel?
Originally posted by Khazmadu View PostJust to be clear with envirement you mean a Spherical Image like an HDRI? In that case you can simple use a Vray Extra Texture an a Vray Placement node to make that.
I'm doing my compositing in Nuke and I want an unpremultiplied alpha.
So I need to render my scene on a black background and render the enviroment map out separately.
To avoid fringing I unpremult my image, grade it etc and premultiply the alpha then composit it back together.,
I was trying to find out if there is a way of having environment map in (without any geometry) a separate channel.
Thats exaclty what I meant.
You can do that with an extra texture like this:
Set the Vray Placement to Spherical and connect it with the UVs of the File Node
You need a Geometry in the Scene because the ExtraTex will be mapped on that.
So just make an Big Sphere around your Scene and give it a Black Shader.
You can turn off everything except Primary Visibility.
Originally posted by nomads View Post...exclude everything from extra texture except the sphere.
If you exclude something will it be rendered black in the Extra Texture. I can't test it Since I have only Vray 2.45 here but I thing this I what you get if you exclude them.
