small white dots visible after rendering
  • small white dots visible after rendering
    I have new problem ,that is small white dots are coming on the glass object and water meterial while iam rendering with v-ray sincfiltter. I dont have any problem when iam doing mitchel_netravaly anti alaising filtter also its not visible when i am converting to the jpeg format at the post production stage.
    The dots are coming when iam using only v-ray sincfilter or catmull .
    I should want to use v-ray sincfilter,! so there is any trick. please help me.
    Thank you.
    If you are using sincfilter to get nice sharp edges then simply turn off all filtering, especially the Default area filter as this blurs things too much.
    Using NO filter also renders quicker.
    Hope this helps
      sorry, could u explain it again pls. i dint get you what your meaning.
      Did you got my problem , what iam facing!..
