Getting Dark Eye Cornea With VRay
  • Getting Dark Eye Cornea With VRay
    While rendering with VRay I am getting the eye cornea as totally dark. Please help.
    Regards,
    Vikas
    It would help if you can post an image or explain your setup a bit.
      The setup details:
        The cornea is shown slightly shifted from the eye for clarity of the problem. It should render transparent to show the iris and the pupil.
          Is it possible that the eyeball is set to invisible for reflections and refractions? It looks that way...
            you might want to check the "Affect Shadows" in the refraction section of your shader.
            Yannick
              Still not working, tried the "affect shadows" option also. This is what I get see the right eye of the man, this is with cornea visible.
                Then it would be best to get us just that part of the scene to vraymaya@chaosgroup.com and our support guys will help you out.
