scripting Output size
  • #16
    The button solution with fixed sizes is a temporary solution only. Most I need two resolutions for a project. I tried to define buttons, but it are a lot and the buttons are not right working some times, if the ratio option is enabled at the VfR options. Than the new ratio isn't used, the set one is keeped. Looks like I need to wait until enabling/disabling the VfR output is scriptable.
    Thank you for the effort.
    • #17
      An other idea - can be read the current set output size from the VfR options? If yes, than the preview button could read the size, multiply it with a percentage (f.ex. 25%) and set this render size, start a rendering and immediately set back the original size.
      • #18
        as you wish. the script will ask for the multiplication factor in the command line.
        -_RunScript (
        Option Explicit
        Dim VRay
        Set VRay = Rhino.GetPluginObject("V-Ray for Rhino")
        Dim Width
        Dim Height
        Dim Mult
        Mult = Rhino.GetReal("Please enter scale factor for Render Output Size:")
        Vray.GetRenderOutputSize Width, Height
        Vray.SetRenderOutputSize Width * Mult, Height * Mult
        Rhino.Command "_Render"
        Vray.SetRenderOutputSize Width, Height
        emil mertzel
        vray4rhinoWiki
        Lookinglass Architecture and Design
        • #19
          That is it! I setup a button with LMB 50% and RMB free input.
          Thank you very much,
          Micha
          • #20
            Happy to help!
            emil mertzel
            vray4rhinoWiki
