phoenix converter
  • phoenix converter
    is possible convert in geometry phoenix fluids ?
    There is a mesher in the newer nightly builds...
      where is that option, sorry but can not find
        in the surface section of the render panel you will find "render as mesh" option
        VRScans developer
          hola, es la opcion geometry mode? lo que necesito es hacer la malla modificable para arreglas detalles , gracias
            hello, is the geometry option mode? I need to make the mesh is modified to manage details, thanks
              No, the geometry option is not used with meshes. Are you using Max or Maya? In Maya the option was changed a couple of times, and I will suggest to wait a couple of days to get the last variant.
                I use 3ds max
