The same thing happening. Also most of times when i hit RT buton , nothing happening (Preparing global light manager... 0% and preview windows is black)
amores - what version are you using? SU 7 doesn't play nice with RT at all. We highly recommend updating to SU 8 or SU 2013 (if you're a part of that beta).
Kontroliora - DR is required for RT rendering. If our XMLDRSpawner process is not running when you try to initiate an RT render (this should start when launching SU), you will not be able to progress beyond the phase you mentioned.
I'm using SU 8.0.16846
one more thing:
DR comes on by default , it's normal.
have the same issue like amores on my pc.
all the time "preparing global light manager" in console
i can only change shadows in rt after closing window and relaunching it.
whats more, is there possibility to use more than one core in rt? for example slave computer with 4 cores for rt.
i found it very slow on my i7 to use only one core for rt when sketchup uses only one so i have spare at least 6 cores for rt actions
Simon
i7 920 @2,67
16gb ram
win 7 x64
gfx 260
su 8.0.16846
vray 1.6beta (vray_beta_16022_sketchup_win_x86)
