300dpi renders in Vray?
  • 300dpi renders in Vray?
    Is it possible to render higher than 72dpi in Vray? say, 300 or 600dpi? The standard Maya settings allow you to change the dpi, but when Vray is enabled, that option is gone.... Any ideas?
    Thanks in advance!
    DPI has no affect on the image. Just go to Photoshop and change it to anything you want.
      its width X dpi and height x dpi so, if you want 8.5" x 11" @300 dpi, you would render out at 2550 x 3300
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
        In max there is a print wizard which allows you to just specify dpi and it configures your render res for you.\
        Edit. Nvm this is in maya
        Dmitry Vinnik
        Silhouette Images Inc.
        ShowReel:
          It's in Max as well =) Rendering / Print Size Assistant.
