Lines while rendering
  • Lines while rendering
    I am rendering an image of a landscape model, and would like to see the lines that you see in the skp-model (but not in the renderings) to make it more clear, is that possible?
    Unfortunately it is not possible do view them directly in the render, but it is possible to use Styles option of Sketchup to generate those lines and then blend the two images with Multiply option into any image editing software like Photoshop / Gimp or etc.
    Styles option are available under Window Menu in Sketch-up. After you are happy with the result you could export the image from File Menu > Export > 2D Graphics.
    Make sure that both image dimensions are exactly the same - otherwise they won't match after placing them on top of each other.
      You could try to use a Toon material?
