lgnition system giu-1902
  • lgnition system giu-1902
    Great Bear Stars Techcom Joint Stock Company - GBS.,JSC introduce a product Ignition System GIU-1902. This product is a system for igniting gas or a fuel-air mixture.
    1. Technical specification
     Power supply: 110VAC/ 230VAC (±10%), 50/60Hz
     Output: 02 electrical outputs suitable for application to the spark plug
     Stored energy: 8 joules of energy for discharge at each spark plug
     Spark repetition rate: approximation 1 spark/second
     The enclosure made from stainless steel
     Cable entry: 01 cable gland M20 for AC power supply cable
     02 High voltage connector (Female).
     IP Rating: IP65
     Environmental: Operating Temp.: 0 ÷ 50 ⁰C
    Storage Temp.: 0 ÷ 85 ⁰C
    Relative Humidity: 0 ÷ 90 %RH (non-condensing)
    2. A complete system includes the following items
     01 High Energy Ignition Unit
     02 High Energy Igniter
     02 Gas Pilot Light
     02 High Energy Cables
     01 Flame-resistant Power Cable
     01 IP65 Start box
    3. Application
     Ignition for crude-oils and gas during well test operation
     Ignition for ceramic furnace, cement furnace, glass furnace, iron and steel furnaces ...
    4. Successful Stories
    Due to high quality of Ignition System GIU-1902, many leading Oil and Gas Corporations in VietNam trust to use. The product have also been exported to Indian, UAE, Indonesia…
    Nguyen The Son
    Mobile: +84 915059226
    Email: theson@gbs-jsc.com
    YM/Skype: theson75
    Great Bear Stars Techcom Joint Stock Company (GBS.,JSC)
    Address: 5th floor, 14 Phao Dai Lang street, Lang Thuong Ward, Dong Da Dist., Ha Noi, Viet Nam.
    Tel: (84-4)6.275 0972 Fax: (84-4).6 275 0973
    Email: info@gbs-jsc.com Website: http://www.gbs-jsc.com
    Good fire ! Good job with Phoenix.
    What is the render time ?
    www.deex.info
      I wasn't aware Phoenix FD could render with fuel instead of CPU.
      Chaos Group guys are always very surprising.
      Few vray stuffs on my blog.
        Hey, hows that foam created on the top of the infinite sea wave?
          seems like spam bot for me.
          VRScans developer
