Irradiance Map 'from file' issues
  • Irradiance Map 'from file' issues
    Does anyone have any advice on loading irradiance maps from file?
    I am trying to follow a tutorial I saw online, which would hopefully speed up render time on a large image. I increased the Irradiance Map and Light Cache settings, ran a low resolution render, and then saved the Light Cache and Irradiance Maps.
    Now, whenever I do a new render, of any resolution, using the Irradiance Map I previously saved, all the colours in the render change. The image is supposed to be of water and some wooden buildings. It comes out fine when I use the 'single frame' irradiance map setting, but the colours across the whole image become neon when I use the 'from file' option.
    Do I need to change other settings as well as just selecting 'from file'?
    What version of V-Ray you are using?
