Good Morning friends,
I have a simple scene with a ground, a sphere and a cube. I'm trying to render each object separately so that i can composite into after effects.
I tried using the VrayObjectSelect element to achieve this.
What i did was assign object id to each object. Then i went into render elements and created 3 VrayObjectSelect element, each one with a differente ID (1,2 and 3). But after the rendering, each channel has the correct object rendered but all the other objects appear black.
The result i was trying to achieve was in each channel have the correct object rendered and all the others not seen (maybe transparent).
Am i doing something wrong ?
Regards,
Bleeding_me
Regards,
Bleeding_me
