Help with an error and related crashes
  • Help with an error and related crashes
    I had problems since i first installed Vray 1.6 beta. Firstly I couldn't use the use A use B feature in the frame buffe, it caused bug slat and when tried the new vray 2.0 beta i couldn't import new materials ( i have already reported it as bug).
    I installed a new plug in called additional folders and when i run it i get this message
    "Message from AddinitalPluginFolders
    2 ERRORS: The following plugins had errors and may not be fully loaded.
    PLUGIN:libcgautth.dylib
    FOLDER:/Sketchup 2013/Sketchup/Plugins/Vfs
    ERROR: no such file to load -- libcgauth.dylib [in ! AdditionalPlugFolders.rb: - #require(): line 277]
    PLUGIN: R2P.rb
    FOLDER:/Sketchup 2013/Sketchup/Plugins/Vfs/Ruby
    ERROR: under fined method 'entityID' for nil:NilClass [in R2PCallbacks.rb: - #edit_material(): line 116]
    Sketchup 2013
    MAc OSX 10.8.4
    Maybe it helps fix the bug...
    if you remove the "AddinitalPluginFolders" plugin, do both messages disappear? We are a rather involved SketchUp plugin, there are hundreds or thousands of SketchUp plugins out there that are simply one .rb file. I doubt that any plugin management software can really manage our plugin very well, so if it's attempting to do that, I would suggest not using that management plugin
    Devin Kendig
    Developer
    Chaos Group
      PLUGIN: R2P.rb
      Sketchup 2013
      MAc OSX 10.8.4
      I think you need to run VRay For Sketchup both sketchup PRO 8 And 2013 . . . . .
        I also cant add material in vray 2.0 beta. I get bugsplat every time I try please help
          What do you mean by "add material" - you are trying to import a material into material-editor or you are creating a new material and you are trying to apply it to scene-geometry ?
            Hi which version are you using ? VRay For Sketchup 2.00.2xxxx . . . ?
              Import a material
                  2.00.23490
                  Yes you are right. when i was import glass material in vray material editor opacity is good. but i was checked opacity in sketchup material editor is not change. i have problem when importing glass material. . . .
                  thanks
                    Would it be possible to attach one of those problematic materials here, or send a direct link for downloading ?
                    Thank you very much in advance.
                      We had issue importing materials and with the transparent option. We already fixed those issues. The fix will be available in the next release.
                      Best
