Cant get wavelets to work
  • Cant get wavelets to work
    Hey guys, any idea what Im doing wrong?
    I create a simple smoke src and container. I get a sim running, and it looks like I expect: Basic, low res smoke sim. I have Temperature, UVW, Smoke, Wavelet and vel checked in the output.
    Once thats done I check on 'resimulate'. It looks the exact same.
    Affect: Grid
    Amplify resoultion 2
    Wavelet nice
    strength: 5
    cutoff .001
    quality 2
    temp channels UVW/Wavelet/Velocity
    Any suggestions?
    Follow up - It seems the high-res wavelet smoke IS being saved out correctly. Is there an easy way to toggle the display of the high vs lowres smoke without having to manually paste the path into the input path?
      when the resimulation option is enabled the input of the resimulation panel is used, you just have to keep the option on
      ______________________________________________
      VRScans developer
